Shows minimum time-to-live (TTL) value for Layer 7 policy/application signature.
N/A.
The TTL minimum value set by the following command:
configure policy app-signature minimum-ttl [none | 1 | 5 | 10]
The following example shows the minimum TTL value:
# show policy app-signature Policy Application Signature minimum DNS-reply TTL value is 5 minutes
This command was first available in ExtremeXOS 30.5.
